coq-club - [Coq-Club] can a simple proof by induction on nat fail at Qed?
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] can a simple proof by induction on nat fail at Qed?
  • Date: Wed, 5 Mar 2008 17:29:43 +0100
  • Organization: IRIT
Hello,
The following proof script only has definitions of type transformations and
functions by induction on nat. Also the proof of the last lemma is by
induction on nat. How can it be that the final Qed is not accepted but gives
me the error message
Error: The term
 "fun (n : nat) (A : k0) =>
  eq_ind_r
    (fun l : list (Pow Bush n A) =>
     flat_map (fun x : Pow Bush n A => BushnToList n A x) l = nil)
    (refl_equal nil) (BushToList_bnil (Pow Bush n A))" has type
 "forall (n : nat) (A : k0),
    (BushToList (bnil (Pow Bush n A)))" while it is expected to have type
 "forall (n : nat) (A : k0), BushnToList (S n) A (bnil (Pow Bush n A)) = nil"
Thank you in advance,     Ralph
http://www.irit.fr/~Ralph.Matthes/
The script is as follows and has been tested for version 8.1pl3:
Set Implicit Arguments.
Require Import List.
Definition k0 := Set.
Definition k1 := k0 -> k0.
(** iterating X n times *)
Fixpoint Pow (X:k1)(k:nat){struct k}:k1:=
  match k with 0 => fun X => X
             |  S k' => fun A => X (Pow X k' A)
  end.
Parameter Bush: k1.
Parameter BushToList: forall (A:k0), Bush A ->  list A.
Definition BushnToList (n:nat)(A:k0)(t:Pow Bush n A): list A.
Proof.
  intros.
  induction n.
  exact (t::nil).
  simpl in t.
  exact (flat_map IHn (BushToList t)).   (* flat_map from List *)
Defined.
Parameter bnil : forall (A:k0), Bush A.
Axiom BushToList_bnil: forall (A:k0), BushToList (bnil A) = nil(A:=A).
Lemma BushnToList_bnil (n:nat)(A:k0):
  BushnToList (S n) A (bnil (Pow Bush n A)) = nil.
Proof.
  intros.
  simpl.
  rewrite BushToList_bnil.
  simpl.
  reflexivity.
Qed.
