coq-club - [Coq-Club] Stack overflow on large nats
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Stack overflow on large nats
  • Date: Mon, 24 Mar 2008 13:14:15 +1100
Hi,
The following definition results in a stack overflow from coqc:
    Definition unicode_codepoint (n:nat) : Prop :=
        n < 1114112.
Presumably some code is trying to process 1 million nested S(...) constructors and isn't tail-recursive.
I've replaced it with this definition, using the N type instead of nat, that seems to work:
    Definition unicode_codepoint (n:N) : Prop :=
        Ncompare n (1114112%N) = Lt.
Is it impossible to manipulate numbers of reasonable size using nat? Is it recommended to use N instead?
Best regards,
Michael
Print XML with Prince!
http://www.princexml.com
