- To: marko AT ffri.hr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Is it possible to compare hypotheses over subgoals
- Date: Fri, 4 Apr 2008 09:27:05 +0100
- Organization: School of Informatics, The University of Edinburgh
On Friday 04 April 2008 08:30:22
marko AT ffri.hr
wrote:
> Greetings,
> I send this problem on this mailing list already but question was little
> different:
> How to compare hypotheses over subgoals?
> But now I am asking: "Is it possible to compare hypotheses over subgoals?"
> So is it possible in environment:
> Subgoal 1:
> H : x=value_1
> Subgoal 2:
> H : x=value_2
> Subgoal n:
> H : x=value_n
> find out are all x's have the same or different values and then to apply
> different tactics according of this knowledge?
> I spend five (5) days to find solution but every idea failed (pattern
> matching, rewriting, abstracting lemma from one subgoal and applying to
> other subgoals, etc...)
> Yves Bertot already answers me that he doesn’t believe I can and I'm
> gratefully for the answer.
> But, I need to know is it impossible for sure? Are all tactics forbid it?
> Or is it maybe possible but nobody did something like that?
If you need more power than Ltac will give you, you can always write a tactic
in OCaml that will do what you want. However, I would advise you to consider
the reason you need such a tactic (i.e. what is the actual high-level problem
you're trying to solve?) and ask you to consider alternative solutions that
do not require tactic use with the behaviour you specify.
Regards,
Sean
- [Coq-Club] Is it possible to compare hypotheses over subgoals, marko
- Re: [Coq-Club] Is it possible to compare hypotheses over subgoals, Sean Wilson
- Re: [Coq-Club] Is it possible to compare hypotheses over subgoals, Andrew McCreight
