- From: Pierre Cast�ran <pierre.casteran AT labri.fr>
- To: Joan Josep Jim�nez Puig <jumi99 AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Exercise
- Date: Sat, 19 Apr 2008 17:52:34 +0200
Hi,
You can get a solution of the bitwise or on binary wordsin the tutorial on
[Co]inductive types (section "A case study in dependant elimination")
http://www.labri.fr/perso/casteran
A former (quite more compact) solution can be found on
http://www.labri.fr/perso/casteran/CoqArt/structinduct/binary_word_or.html
There are also some contributions by various people in the Coq-club mailing
list archive.
Best regards,
Pierre
Quoting Joan Josep Jiménez Puig
<jumi99 AT gmail.com>:
Hi,
first of all apologies for my english :) I'm reading the Coq'Art book and
there's
one exercise I cannot solve. It is from chapter 6, Dependent Inductive
Types.
I have defined a type (binary_word : nat -> Set) of strings of bits of a
known length.
The exercise is to compute the bit-wise "or" of two binary_words.
Here's the code I've done, but it doesn't work because in the recursive call
there's a problem with the parameter n. If I put x it will complain
about the type of bw2' and if i put x' it will complain about bw1'.
I have to use somehow the fact that x=x', but I don't know how to do it.
Inductive binary_word : nat -> Set :=
|F : binary_word O
|M : forall n:nat, Bit -> binary_word n -> binary_word (S n).
Fixpoint binary_word_or (n:nat) (bw1:binary_word n)
(bw2:binary_word n) {struct bw1}
: binary_word n :=
match bw1 in binary_word q return binary_word q with
| F => F
| M x b bw1' =>
match bw2 in binary_word q return binary_word q with
| F => F
| M x' b2 bw2' =>
M x (bit_or b b2) (binary_word_or x bw1' bw2')
end
end.
Thanks.
Pierre Castéran
- [Coq-Club] Exercise, Joan Josep Jiménez Puig
- Re: [Coq-Club] Exercise, Pierre Castéran
