[Coq-Club] Coq rejects recursive call with obviously smaller principal argument
chronological Thread
- From: "Eelis van der Weegen" <coq-club AT contacts.eelis.net>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Coq rejects recursive call with obviously smaller principal argument
- Date: Tue, 22 Apr 2008 21:00:17 +0200 (CEST)
- Importance: Normal
Greetings. Given the following inductive definition:
Inductive Tree (A: Set): Set :=
| Leaf: A -> Tree A
| Node: list (Tree A) -> Tree A.
Coq rejects the following:
Fixpoint f A (l: list (Tree A)): unit :=
match l with
| Node x :: y => f A x
| _ => tt
end.
(* error: Recursive call to f has principal argument equal to "x"
instead of y *)
First question: Since x is obviously a subterm of l, should Coq not easily be
able to conclude that the recursive call is safe? If not, is there some
theoretical limitation here?
The following workaround works:
| Leaf: A -> Tree A
| Node: MyList A -> Tree A
with MyList (A: Set): Set :=
| Nil
| Cons: Tree A -> MyList A -> MyList A.
Fixpoint f A (l: MyList (Tree A)): unit :=
match l with
| Cons (Node x) y => f A x
| _ => tt
end.
(* Ok. *)
Second question: Is there a less annoying workaround that doesn't require me
to duplicate lots of existing functions and theorems operating on lists?
Regards,
Eelis
P.S. In the above, f is obviously a silly function. However, this is only an
isolated testcase; in my actual development I'm trying to define a monadic
bind operation for Tree.
- [Coq-Club] Coq rejects recursive call with obviously smaller principal argument, Eelis van der Weegen
