- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] numeric sums over predicates
- Date: Fri, 2 May 2008 11:09:52 -0500 (CDT)
I apologize for the possible multiple postings (the message sent from my
other email account did not make it to the mailing list so far).
Given the definition
Definition Less (n:nat) : Set := {i | i < n}.
I am trying to define a sum operator that takes a number n, a predicate P :
Less n -> Prop,
and a function f : {i : Less n | P i} -> nat, and returns the sum of all
numbers f i such that
i : Less n and P i holds. Informally I would define this sum by doing a
case analysis, at the induction step n' to n'+1, on whether P n' holds, case
in which I add 0, otherwise I add f n'. However, even if I assume excluded
middle, Coq would not let me do this case analysis, since I am attempting to
eliminate Prop on Set.
Working with boolean predicates P : Less n -> bool does not seem to help
either, since then the functions f would be in
f : {i : Less n | P i = true} -> nat and after matching P n' with true I do
not seem to have access to a proof of
P i = true in order to apply f to n'.
(In the discussion above, I have identified elements of Less n with elements
of nat, in the "Program" style, to keep the ideas clear.)
Is what I am trying to do violating the constructivity principles behind Coq?
I would be grateful for any advice on this.
Regards,
Andrei Popescu
- [Coq-Club] numeric sums over predicates, popescu2
