- From: "Theodoros G. Tsokos" <T.Tsokos AT cs.bham.ac.uk>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] impredicative-set in proof general
- Date: Mon, 19 May 2008 10:51:36 +0100
Dear all,
I would like to run ProofGeneral with option -impredicative-set. I tried the following two I found on a previous thread of Coq-Club:
1) To add this at the end of my file:
*** Local Variables: ***
*** coq-prog-name: "coqtop -I . -emacs -impredicative-set" ***
*** End: ***
2) To edit the "Menu -> ProofGeneral ->Advanced -> customize -> Coq -> Coq prog name".
On the first case, it still outputs: "User error: Needs option -impredicative-set" and on the second case it outputs: " Starting process: /usr/bin/coqtop.opt -impredicative-set -emacs-U..failed".
Any help/advice please? Thanks in advance,
Theo.
- [Coq-Club] impredicative-set in proof general, Theodoros G. Tsokos
- Re: [Coq-Club] impredicative-set in proof general, Florian Hatat
