- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] dependent inversion
- Date: Mon, 02 Jun 2008 14:45:16 +0200
Hello,
I'm having some (I guess) usual problem with dependent types, and I
don't know the (I hope) usual way to handle it. In the following
example, I've tried to reproduce the minimal subset of my problem :
Inductive Nat : nat -> Prop :=
| c0 : Nat 0
| cn : forall n, Nat n -> Nat (S n)
Variable F : Set.
Variable h : F -> nat.
Inductive T : Set :=
| app : forall (s:F) (t:Nat (h s)), T
What's releveant is that Nat is a dependent inductive type and that app
put a constraint on the type of t.
Then, if we define a predicate G like this :
Definition G (n:nat) (l:Nat n) := True.
Dependent inversion on l for the following goal succeeds.
Coq < Goal forall (s:F) (n:Nat (h s)), G (h s) n.
1 subgoal
forall (s : F) (n : Nat (h s)), G (h s) n
Unnamed_thm < dependent inversion n.
2 subgoals
s : F
n : Nat (h s)
H0 : 0 = h s
G 0 c0
subgoal 2 is:
G (S n0) (cn n0 n1)
Whereas dependent with the following definition :
Definition G (n:nat) (t:T) (l:Nat n) := True.
the following goal does not allow dependent inversion.
Coq < Goal forall (s:F) (n:Nat (h s)), G (h s) (app s n) n.
1 subgoal
forall (s : F) (n : Nat (h s)), G (h s) (app s n) n
Toplevel input, characters 0-21
Error: Illegal application (Type Error):
The term "app" of type "forall s : F, Nat (h s) -> T"
cannot be applied to the terms
"s" : "F"
"n1" : "Nat n0"
The 2nd term has type "Nat n0" which should be coercible to
"Nat (h s)"
This is partly explained by the fact that the following fails:
1 subgoal
Unnamed_thm < intros.
1 subgoal
s : F
n : Nat (h s)
G (h s) (app s n) n
Unnamed_thm < generalize (h s).
Toplevel input, characters 0-16
> generalize (h s).
The term "G" of type "forall n : nat, T -> Nat n -> Prop"
"n0" : "nat"
"app s n" : "T"
"n" : "Nat (h s)"
The 3th term has type "Nat (h s)" which should be coercible to
"Nat n0"
My guess is that I should write some inversion principle by hand which
would look like :
forall n, n=(h s) -> ....
but I didn't manage to.
Thanks in advance for your answers.
- [Coq-Club] dependent inversion, Paul Brauner
