- From: Hermann Lehner <hermann.lehner AT inf.ethz.ch>
- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Passing Fixpoint as parameter
- Date: Wed, 4 Jun 2008 12:44:16 +0200
Dear Club,
I'm trying to define a mutual recursion between a 'Fixpoint' and a well-founded 'Function'. As I don't see how this is done by defining them at the same time by using 'with', i tried to pass the Fixpoint to the Function as argument it.
After some simplification, and exchanging the Function by another Fixpoint (It triggers the same message), I get an error that I simply don't understand in the following (ok, stupid) definition:
Inductive Data : Type :=
| D1 (d : Data)
| D2 (d : Data).
(* No real fixpoint, just to show the problem *)
Fixpoint Fix1 (f : Data -> Data) (d : Data) {struct d} : Data :=
match d with
| D1 d' => f d'
| D2 d' => d'
end.
(* The same as above, this time using 'Definition' *)
Definition Dev1 (f : Data -> Data) (d : Data) : Data :=
match d with
| D1 d' => f d'
| D2 d' => d'
end.
(* This works fine *)
Fixpoint FixOK (d : Data) : Data :=
match d with
| D1 d' => Dev1 FixOK d'
| D2 d' => Dev1 FixOK d'
end.
(* This fails *)
Fixpoint FixFAIL (d : Data) : Data :=
match d with
| D1 d' => Fix1 FixFAIL d'
| D2 d' => Fix1 FixFAIL d'
end.
The last Fixpoint declaration fails with:
Error:
Recursive definition of FixFAIL is ill-formed.
In environment
FixFAIL : Data -> Data
d : Data
d' : Data
Recursive call to FixFAIL has not enough arguments.
Recursive definition is:
"fun d : Data =>
match d with
end".
So it seems to work when using 'Definitions', but not with 'Fixpoint' and also not with 'Function' ... any clue why?
I guess it's related to http://www.nabble.com/Program-Fixpoint's-binding-behavior-td17478094.html , but I can't see a solution for this. I'm working with the SVN Version of Coq.
Thanks!
Best Regards
Hermann
http://www.hermann-lehner.com
- [Coq-Club] Passing Fixpoint as parameter, Hermann Lehner
