- To: "Andrew McCreight" <continuation AT gmail.com>
- Cc: "Coq List" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] setoids and functors
- Date: Fri, 6 Jun 2008 10:51:33 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:cc:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=MpSlns/p+B+KmKhLivoj0ddXA7ckcxStUFY+/DiY5+8wg7YKi+sbW5zTiznspnIAXO 9hnIq/1OnkFNw2H364awyr9EqmTB1Gmd5QVKsfbDQcDEQRyzeXRZnCPE7PBqOvc2ZylT VWvnKs1cQ4/7PskE2jTSZbYLwiHBTe1POgriA=
I tried something like that, but I don't understand how it can be made
to work. Is there a way to write a signature for FSetFacts that
declares information about the setoid it defines? Otherwise, the
client functor G will not be able to use rewriting in the setoid. To
give a concrete example, how can I design G so that the rewriting
tactic in the proof will work, other than uncommenting the third line?
Require Import FSets.
Module G (MyFSet : FSetInterface.S).
(* Module MyFacts := FSetFacts.Facts MyFSet. *)
Lemma foo : forall x y s,
MyFSet.E.eq x y -> MyFSet.In x s -> MyFSet.In y s.
Proof.
intros x y s Heq H. rewrite -> Heq in H. assumption.
Qed.
End G.
- Aaron
On Thu, Jun 5, 2008 at 5:58 PM, Andrew McCreight
wrote:
> I had this exact same problem. I think my solution was to define a
> signature for sets + (some subset of) FSetFacts and use that as a functor
> argument instead of the raw set. It is a little ugly, especially given that
> you can't really unpack a module inside of another module, so there is
> always an extra level of indirection (unless you import the outer module,
> which is not something you usually want to do, because you'll usually have
> more than one kind of set sitting around).
> -Andrew
> On Thu, Jun 5, 2008 at 2:21 PM, Aaron Bohannon
> <bohannon AT cis.upenn.edu>
> wrote:
>> I've noticed a bad interaction between setoids and the module system.
>> If a setoid is defined in a functor (let's call it F), then apparently
>> that functor must only be instantiated exactly once (otherwise, you
>> will see a long warning and rewriting in the setoid will stop
>> working). This doesn't sound like a huge problem (why would you
>> instantiate a functor twice?), until you try to write another functor
>> G (in its own file) with proofs that require rewriting in the setoid
>> defined in F. In order for the file containing G to compile, G must
>> instantiate F internally. Thus, one must be sure to never instantiate
>> F outside of G. OK, now that's already a software engineering
>> nightmare, but worse, imagine two functors G1 and G2 that both require
>> access to rewriting in the setoid defined in F. Now you're completely
>> stuck.
>> I'm not sure if I can call this a bug, because there is no simple,
>> obvious solution. The only thing that comes to mind would be to allow
>> abstraction over setoid and morphism declarations by including them in
>> module types. Is anybody working on this issue? Does anybody know of
>> good work-arounds? For a specific example of such a functor F, see
>> the FSetFacts file from the standard library.
>> - Aaron
>> Bug reports: http://logical.futurs.inria.fr/coq-bugs
>> Archives: http://pauillac.inria.fr/pipermail/coq-club
>> http://pauillac.inria.fr/bin/wilma/coq-club
>> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] setoids and functors, Aaron Bohannon
- Re: [Coq-Club] setoids and functors,
Andrew McCreight
- Re: [Coq-Club] setoids and functors, Aaron Bohannon
- Re: [Coq-Club] setoids and functors, Andrew McCreight
Pierre Letouzey
Aaron Bohannon
Pierre Letouzey
- [Coq-Club] Re: setoids and functors, Samuel Bronson
Pierre Letouzey
Aaron Bohannon
Andrew McCreight
