- To: "Jean.Duprat" <duprat AT ens-lyon.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] About the output file
- Date: Fri, 13 Jun 2008 11:13:38 +0200 (CEST)
- Importance: Normal
Hi,
I had the similar needs and I solved it by redirecting output in some txt
file and then by parsing this txt file.
So, something like this:
coqtop.opt -load-vernac-source your_environment.v > "output.txt"
and then you can parse by some MS-DOS or Windows parser lines which
containe hypotheses you need (everything you can do automaticaly).
Hope this help,
Marko Malikoviæ
> Hi,
> We want to filter the output file that coqtop sends to the standard
> output.
> Our goal is to select some hypotheses in the environment according to
> the fact they contain
> some words.
> Our first problem is to split the output into hypotheses. The carriage
> return seems not sufficient
> since a long hypothesis occupies several lines.
> Is there a location where we can find the syntax of the output ?
> Thanks,
> Jean Duprat
> Bug reports: http://logical.futurs.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] About the output file, Jean.Duprat
- Re: [Coq-Club] About the output file, marko
