- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Module types with definitions which refer to parameters
- Date: Sun, 6 Jul 2008 01:49:19 -0400
I saw some old discussions about this in the archives, but I couldn't figure out an answer.
If I want to define a module type with parameters and definitions, where the definitions depend on the parameters, is there a way to do this without having to copy and paste the definitions in modules which instantiate the module type? And beyond that, can I prove things about a module type (without instantiating the parameters), and then refer to those lemmas within a module where I *have* instantiated the parameters?
I hope my sample code below illustrates what I mean. (I use an Inductive definition below, rather than a regular Definition, because in my actual development, I have Inductive definitions, and I wanted to make sure any response doesn't depend on having only Definitions.)
Thanks for any assistance.
As an aside, I read a suggestion that Records are better to use than Modules anyway. If they provide a solution, great; I'm not committed to Modules.
-Elnatan
Require Import List.
Module Type MY_SIG.
Parameter aList : list nat.
Inductive sublist : list nat -> Prop :=
| sl : forall L n, In n L -> In n aList -> sublist L.
End MY_SIG.
Declare Module X : MY_SIG.
Import X.
(* Prove things about any MY_SIG here *)
Module MyMod : MY_SIG.
Definition aList := 1::2::4::nil.
(* Prove things about MY_SIGs with this particular value for the parameter, *)
(* but I should be able to refer to things I proved above *)
End MyMod.
(* This gives an error, but I want the definition of sublist from MY_SIG to be used. *)
(* I don't want to have to redefine it here. *)
- [Coq-Club] Module types with definitions which refer to parameters, Elnatan Reisner
