coq-club - Re: [Coq-Club] Categorical programming with more than one category?
chronological Thread
  • From: Arnaud Spiwack <Arnaud.Spiwack AT lix.polytechnique.fr>
  • To: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Categorical programming with more than one category?
  • Date: Mon, 07 Jul 2008 19:08:58 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding:sender; b=RMqHrbu8+c/0eMjA9/eWR9gku/uB440sNjqfaqYIE6a3TnNhua7zcRNVIcU8jF6hEq Ls1hVpvBeyyzDn8/fCn0AwJhW0i8eWYRBEu1nn2zcLThiF3YRVI2RR45CT+G0VhRfl7C 1lCgywPhcogw3r/xrYtqEBcfhq116i6f9QgME=
Hello,
Are there any developments in Coq (or any other proof assistant)
which use more than one category-theoretic category in some
interesting way, and yield a useful program?
Nothing finished that I know of, but I'm currently developping a very category-theoretic program. Namely a CAS for homological algebra. The general pattern is that I use categories as data abstractions over structures (additive categories are apparently sufficient to develop all effective homological algebra, but can be instantiated with a large variety of structures).
This is the most obvious use of categories for programming.
What I am getting at is: can more than one category be useful in
programming (as opposed to merely doing mathematics)?
Depending on what you mean by "merely doing mathematics", the answer above can be a positive answer or not.
However there is a more specific answer, categories also allow to define generic notions of (finite) "products", "sum", "initial" and "terminal" object. Any categories which have all these contain all the recursively defined datatypes (vectors, option type, Chris Okasaki's binary lists defined recursively over binary natural numbers...), you need more assumptions to have the inductively defined datatypes (like lists) but it's also possible.
Using "categorical datatypes" of this sort allow to define generically many actual datatypes.
My main example (I haven't dug very far in it) is C's option type. In C, functions like "find the first occurence of character c in string s" return a positive integer. But as they can fail, they also can return -1 as a failure case. This is generally considered bad practice when you can define "int option" (or even better "nat option") which gives you much more information. Arguably the option type has the drawback of being slower to use than a plain integer. However in every category which has all finite sums and an initial element, We can define A option as being A+0 . The category of all integer intervals is such a category, thus it has an option type (which if written properly can make "nat"+0 be exactly [| -1, +infinity |] ). Thus you can program in the potentially faster C style without sacrifying type safety or genericity.
Well this is a bit theoretical at this point, but I hope to be able to give it more precise meaning sometimes.
If we take a subcategory of the Set category, we can define, for
example, monad type constructors which only obey the monad laws for
certain arguments (those denoted by the objects of the subcategory).
However, I am not aware of any such "partial monads" being used
anywhere.
It's most likely because it's not possible in conventional languages. But I can't think of an example for this particular case.
Arnaud Spiwack
