- To: Coq-Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Automatically unfolding simple definitions
- Date: Thu, 10 Jul 2008 15:42:08 +0100
- Organization: School of Informatics, The University of Edinburgh
On Thursday 10 July 2008 15:21:24 Adam Chlipala wrote:
> Sean Wilson wrote:
> > As a simple example of what I need, given this definition:
> > Definition f x y := plus x y.
> > The following is true:
> > Goal forall x y, f x y = f y x.
> > My proof automation can prove this goal but only if "f" is unfolded
> > first.
> It seems dubious that you can even describe a general tactic for this
> kind of thing. [plus] is no more privileged as a "primitive definition"
> than your [f], as far as Coq is concerned.
I thought there might be problems like this when I wasn't sure what I meant
by "simple definition"...
> The heuristic you suggest
> for not unfolding recursive function definitions might work, but you
> might run up against a library function that you want to consider
> "primitive" that happens to be defined in terms of a recursive helper
> function, and then (if I understand you) the heuristic wouldn't do what
> you want.
Yes, this could cause problems in some cases. As it is a heuristic though and
I don't expect to be able to automate everything, as long the heuristic works
in most cases, it should be helpful. I could do analysis of definitions first
to avoid unfolding such problematic functions.
> I recommend parameterizing your automation on a simplification tactic,
> which could just be an [unfold] with a long list of identifiers.
I have such a parameter already, but don't want to force the user to provide
identifiers to unfold when it can be done automatically. Otherwise, the user
is forced keep updating the simplifier to keep up with new definitions.
Thanks for the feedback!
Regards,
Sean
- [Coq-Club] The greatest common divisor in the standard library, Andrés Sicard-Ramírez
- Re: [Coq-Club] The greatest common divisor in the standard library, Johannes Waldmann
- [Coq-Club] Automatically unfolding simple definitions,
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions,
Adam Chlipala
- Re: [Coq-Club] Automatically unfolding simple definitions, Andrew McCreight
- Re: [Coq-Club] Automatically unfolding simple definitions, Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Vladimir Komendantsky
- Re: [Coq-Club] Automatically unfolding simple definitions, Robin Green
Stéphane Glondu
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Stéphane Glondu
Sean Wilson
- Re: [Coq-Club] Automatically unfolding simple definitions, Benjamin Gregoire
Adam Chlipala
