coq-club - Re: [Coq-Club] About dependent elimination or inversion?
chronological Thread
  • To: Gyesik Lee <gyesik.lee AT aist.go.jp>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] About dependent elimination or inversion?
  • Date: Thu, 31 Jul 2008 08:50:28 -0400
Gyesik Lee wrote:
in case of representing the semantics of a language, it is sometimes
necessary to have the uniqueness of the term constructions. But since
terms are usually of dependent types, it is not so simple to prove the
uniqueness because of heterogeneous equality or dependency.
Here is one simple example.
Inductive P : nat -> bool -> Set :=
 T : forall n, P n true.
Goal forall (n : nat) (x : P n true), x = T n.
(* one would try *)
intros n x.
destruct x.
But the tactic destruct fails with the warning (using Coq 8.2beta3)
Error: Abstracting over the terms "n", "b" and "x" leads to a term
"fun (n : nat) (b : bool) (x : P n b) => x = T n" which is ill-typed.
Maybe one has to use first the tactic of the following form
pattern n at nums, true at nums , x at nums
to get a well-typed application term, and then use "destruct". But I
don't understand exactly the process.
[destruct] is only going to work well when _all_ of the arguments of the type family you're destructing are variables. You might also have to run [change] on some of the variables to get their types to match those in the definition of the type family. These restrictions arise from the CIC typing rule for [match], which is the building block for [destruct].
I think that the general problem you're pointing out could be used to solve the higher-order unification problem, so we know it must be undecidable. Tactics like [dependent inversion] make heuristic attempts at solving it in limited cases.
It's hard to give a short description of how to solve this problem in practice. The best I can do is show how to solve your specific example using [JMeq]. (Keep in mind that this involves introducing an axiom, as seen in the manual page for the [JMeq] module.)
Require Import JMeq.
Lemma p' : forall (n : nat) (b : bool) (x : P n b), b = true -> JMeq x (T n).
 destruct x; trivial.
Qed.
Theorem p : forall (n : nat) (x : P n true), x = T n.
 Hint Resolve JMeq_eq p'.
 auto.
Qed.
