- To: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] problems with functionnal inductive types
- Date: Sat, 2 Aug 2008 13:18:56 +0200
Le 2 août 08 à 11:37, Edsko de Vries a écrit :
On Fri, Aug 01, 2008 at 12:36:22PM +0200,
Cedric.Auger AT lri.fr
wrote:
I want to make very simple enumerated types,
so I did:
Inductive enums : nat -> Set :=
| New : forall n, enums n
| Old : forall n, enums n -> enums (S n).
Implicit Arguments New [n].
Implicit Arguments Old [n].
Set Printing All.
Lemma e : forall (e : enums 0), e = New.
intros.
Now I want to destruct e
induction e.
all occurences of O have been replaced by n,
so it "generalize" instead of instantiate,
and our proof cannot succeed this way
is there anyway to prove this lemma, or to implement
enumerated types without using Fsets & co, and without using
like enums m = {n | m < n}?
You can use dependent inversion:
dependent inversion e.
reflexivity.
Qed.
Hello,
Beware that this works only because you are in a very favorable case where
the goal can actually be generalized before doing induction, like this:
intros.
generalize (refl_equal 0). set(t:=0) at 1.
generalize 0 e. subst t. destruct e0. intros. reflexivity.
intros. discriminate.
Qed.
Indeed, one can generalize the [n] argument of [New] in this case, transforming
the goal
[@eq
(enums 0) e (@New 0)] into a
[forall n (e : enums n), @eq (enums n) e (@New n)]
Provided you keep information on [n] on the side (the [generalize (refl_equal 0)]
trick) it will work.
Alas, this is not possible in general, consider:
Inductive vector : nat -> Set := vnil : vector 0.
Lemma e' : forall (v : vector 0), v = vnil.
Proof.
intros. dependent inversion v.
Here there is no way to generalize [vnil] into a [vector n] so inversion
fails. The technique used by the [dependent destruction] tactic avoids this
by not attempting any generalization of the goal and so works in both cases, e.g:
Require Import Equality.
Proof.
intros. dependent destruction v.
reflexivity.
Qed.
Hope this helps,
Matthieu Sozeau
http://www.lri.fr/~sozeau
- [Coq-Club] problems with functionnal inductive types, Cedric . Auger
- Re: [Coq-Club] problems with functionnal inductive types,
Edsko de Vries
- Re: [Coq-Club] problems with functionnal inductive types, Matthieu Sozeau
Edsko de Vries
