- From: "Samuel E. Moelius III" <moelius AT cis.udel.edu>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Questions on Convertibility and Dependent Types
- Date: Wed, 13 Aug 2008 10:10:54 -0400
In the code below, I would like that when I enter
Eval compute in (test (Zero 0)).
I get back
Vnil nat
As things currently stand, this is not the case.
Question 1: Am I correct that this is due to the use of opaque constants such as eq_add_S and UIP_refl?
Question 2: Were I to redefine these constants so that they were transparent, and then use the new constants, I still would not get what I want because UIP_refl is proven using the axiom eq_rect_eq, correct?
Question 3: Is there a way to get what I want using Bounded_elim as I have defined it, or am I on the wrong track?
Any help would be greatly appreciated. Thanks in advance.
Sam
Require Import Bvector.
Require Import Eqdep.
Inductive Bounded : nat -> Set :=
| Zero : forall (n : nat), Bounded (S n)
| Succ : forall (n : nat), Bounded n -> Bounded (S n)
Definition Bounded_elim : forall (m : nat) (i : Bounded (S m))
(A : Type),
(forall (n : nat) (p : S n = S m),
i = eq_rect (S n) Bounded (Zero n) (S m) p -> A) ->
(forall (n : nat) (p : S n = S m) (j : Bounded n),
i = eq_rect (S n) Bounded (Succ n j) (S m) p -> A) -> A.
intros.
remember i as j.
destruct i.
(* Case "Zero" *)
apply (X n (refl_equal (S n))).
simpl.
apply Heqj.
(* Case "Succ ..." *)
apply (X0 n (refl_equal (S n)) i).
simpl.
apply Heqj.
Defined.
Fixpoint Bounded_to_nat (n : nat) (i : Bounded n) {struct i} : nat :=
match i with
| Zero _ => 0
| Succ n0 i0 => S (Bounded_to_nat n0 i0)
end
Definition test : forall (i : Bounded 1),
vector nat (Bounded_to_nat 1 i).
intros.
apply (Bounded_elim 0 i).
intros.
rewrite H; clear H.
assert (n = 0). apply (eq_add_S n 0 p).
revert p. rewrite H. intro.
assert (p = refl_equal 1).
apply (UIP_refl nat 1).
rewrite H0.
simpl.
apply (Vnil nat).
intros.
rewrite H; clear H.
revert j p.
rewrite H.
intro.
inversion j.
Defined.
- [Coq-Club] Questions on Convertibility and Dependent Types, Samuel E. Moelius III
