- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Mutually recursive co/inductive types
- Date: Thu, 14 Aug 2008 14:48:40 +0200
In this specific case it is easy to separate the inductive and coinductive part by generalizing the first with respect to the second:
Inductive StrProg (Str: Set -> Type)(A:Set): Type :=
darr : Str A -> StrProg Str A
| map : forall (B: Set), (B -> A) -> StrProg Str B -> StrProg Str A
| merge : (A -> A -> Ordering) ->
StrProg Str A -> StrProg Str A -> StrProg Str A.
CoInductive Stream (A : Set) : Type :=
cons : A -> StrProg Stream A -> Stream A.
It would be interesting to see if there is an example in which this trick doesn't work.
Venanzio
coq-club-request AT pauillac.inria.fr
wrote:
Is it possible to write a pair of mutually recursive types of which
one is inductive and the other coinductive, as in:
http://sneezy.cs.nott.ac.uk/fplunch/weblog/?p=109
Jim
- [Coq-Club] Mutually recursive co/inductive types, Jim Apple
- <Possible follow-ups>
- [Coq-Club] Mutually recursive co/inductive types, Venanzio Capretta
