coq-club - Re: [Coq-Club] Prefixes of a vector
chronological Thread
  • To: Adam Chlipala <adamc AT hcoop.net>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Prefixes of a vector
  • Date: Wed, 20 Aug 2008 15:17:17 +0200
Adam Chlipala wrote:
Programs written like this with proof scripts seem hard to read and maintain. Does anyone have any arguments for writing in this style instead of in the style I used in my solution?
I agree with you: For the prefix function, it seems that your recursive implementation of vectors is much nicer that the inductive one. But is it always preferable.
Btw: I have a little module with the equivalence of the two implementations and a third one of vectors as functions on finite types.
See http://www.cs.ru.nl/~venanzio/Coq/Vectors.v.
Using some of the definitions in there, here is another possible way is to answer Samuel's original question:
Fixpoint vec_split (A:Set)(n1 n2:nat){struct n1}:
 vector A (n1+n2) -> (vector A n1 * vector A n2)%type :=
match n1 return vector A (n1+n2) -> (vector A n1 * vector A n2)%type with
 O => fun v => (vec_nil A, v)
| (S n1') => fun v => let (w1,w2):= vec_split A n1' n2 (vec_tail v) in
                       (vec_cons (vec_head v) w1, w2)
end.
Using vec_split is easy to define prefix, but you still have to use rewriting steps inside the definition.
Venanzio
