coq-club - [Coq-Club] proofs related to mutually inductive language constructs
chronological Thread
  • From: Ersoy Bayramoglu <ersoy.bayramoglu AT epfl.ch>
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] proofs related to mutually inductive language constructs
  • Date: Sat, 23 Aug 2008 00:29:25 +0200
Hi,
I'm new to Coq, and I'm trying to mechanize the metatheory of a core module calculus. I'm following the approach described in the paper "Engineering Formal Metatheory". The type system has mutually inductive modules and expressions. Consider the simple lemmas:
Lemma open_te_rec_type_aux : forall e j V i U,
  i <> j ->
  open_te_rec j V e = open_te_rec i U (open_te_rec j V e) ->
  e = open_te_rec i U e.
Lemma open_tm_rec_type_aux : forall m j V i U,
  i <> j ->
  open_tm_rec j V m = open_tm_rec i U (open_tm_rec j V m) ->
  m = open_tm_rec i U m.
The first one is about opening type variables in expressions and the second is about opening type variables in modules. Since modules appear in expressions and expressions appear in modules, proving any of these lemmas require proving the other one first. How can i do these proofs in Coq? Is there a way for the lemmas to refer each other, or to prove them together? The Coq wiki has information on generating mutual induction principles which look quite heavy weight for this sort of thing. Because if I assume one of the lemmas, proving the other one is really trivial. If it's the only way, how can i use the induction principal generated by Scheme - or Combined Scheme - for these proofs?
Thanks,
ersoy
