coq-club - [Coq-Club] Type classes in Coq 8.2
chronological Thread
  • To: Coq Mailing List <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Type classes in Coq 8.2
  • Date: Mon, 25 Aug 2008 16:22:00 -0400
Hi,
I'm taking a look at type classes in the current svn version of Coq 8.2. Below, is a silly example that I have a couple questions about.
Class Foo (A : Type) :=
  op : A -> bool;
  op_axiom : forall (x : A), op x = false.
Lemma test : forall [Foo A] [Foo B] (x : A) (y : B),
  op x = op y.
Proof.
  intros.
  rewrite op_axiom.  (* Succeeds. *)
  rewrite op_axiom.  (* Fails.  Must say (@op_axiom A) instead. *)
First, is the failure of the second invocation of rewrite because of how maximally set implicit arguments and type class inference interact?
Second, are there any particular "style guidelines" for writing proofs involving type classes? The above example maybe suggests that maybe I should be explicit about what type I'm using op_axiom at, i.e., "rewrite (@op_axiom A). rewrite (@op_axiom B)." That seems like it would lead to a more robust proof script in the long run. On the other hand, maybe one wants to omit such information from scripts normally, so instead the implicit arguments on op_axiom should be declared to be non-maximal.
Any thoughts here? I'm simply trying to understand the current design and the expected use patterns. It's looking nice so far. (-:
Cheers,
Brian
