- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: Cedric.Auger AT lri.fr, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: Coq-club digest, Vol 1 #1172 - 3 msgs
- Date: Fri, 05 Sep 2008 19:17:35 +0200
Adam Chlipala a écrit :
AUGER Cédric wrote:
I may be wrong, but there is also cardinal impossibility for that
isomorphism:
cnat is a lot bigger than nat and even bigger than reals (true reals, not
floating ones), since for each real x, there exists a cnat c such that "c
real 0 _ = x", and as there is no bijection between nat and reals, there
is no bijection between nat and cnat.
Isn't every type not provably bigger than [nat] in Coq, since every nameable value of every type (and thus every value that we're sure exists in every model of CIC) corresponds to a finite string of Coq syntax? I'm not so up on the meta-theoretic issues here, but it seems like constructivity should break the usual cardinality arguments.
You can encode Cantor's diagonal argument to prove that any mapping from nat to nat->nat cannot be surjective:
Section Cantor.
Variable f : nat -> (nat -> nat).
Variable f_surj : forall x, exists n, x = f n.
Definition diag n := S (f n n).
Lemma cantor : False.
elim f_surj with diag; intros.
assert (f x x = diag x) by (rewrite H in |- *; trivial).
unfold diag in H0.
apply n_Sn in H0.
trivial.
Qed.
End Cantor.
However, this does not imply that there is no countable model of Coq. It just means that in this case, the function that enumerates all the values of nat->nat does not belong to the model.
Considering the lambda-term model again, nat->nat denotes an enumerable set of lambda-terms, but such an enumeration function cannot be represented as a lambda-term.
Bruno Barras.
- [Coq-Club] Re: Coq-club digest, Vol 1 #1172 - 3 msgs, AUGER Cédric
- Re: [Coq-Club] Re: Coq-club digest, Vol 1 #1172 - 3 msgs,
Adam Chlipala
- Re: [Coq-Club] Re: Coq-club digest, Vol 1 #1172 - 3 msgs, Bruno Barras
Adam Chlipala
