- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Unprovable obligation generated by Program Definition
- Date: Sun, 14 Sep 2008 20:03:44 +0100
- Organization: Swansea University
When the code fragment below is given to Coq (trunk version), the first
generated obligation is not provable (because it is false). Is this is
a bug in the obligation generating code?
More generally, how often should the obligation generator be expected to
generate provable obligations (assuming the overall goal is provable)?
Robin
Set Implicit Arguments. Unset Strict Implicit. Set Reversible Pattern
Implicit. Set Contextual Implicit.
Set Maximal Implicit Insertion.
(* A decidable proposition *)
Definition dec_Prop := { P : _ & { P } + { ~ P } }.
Require Import Program.Basics Program.Syntax List.
Open Scope program_scope.
Implicit Arguments projT1 [[A] [P]].
Implicit Arguments length [[A]].
(* How many of the propositions are true? *)
Definition count_truths := length ∘ flat_map (fun x : dec_Prop => if
projT2 x then [()] else []).
Section Prop_List.
Variable lp : list Prop.
(* Whether the given list is a decider list for lp *)
Definition dec_for : list dec_Prop -> Prop := eq lp ∘ map projT1.
Require Import Program.Tactics.
(* Returns a proposition that is true iff at least one of the
elements of lp is true *)
Program Definition any_of : { p : Prop |
forall ldp, dec_for ldp -> (p <-> count_truths ldp >= 1) }
:= match lp with
cons h t => fold_left or t h
| _ => False
end.
Next Obligation.
This is the state after "Next Obligation":
1 subgoal
lp : list Prop
h : Prop
t : list Prop
Heq_anonymous : h :: t = lp
x : Prop
H0 : forall ldp : list dec_Prop, dec_for ldp -> (x <-> count_truths ldp
>= 1) x0 : Prop
ldp : list dec_Prop
H : dec_for ldp
______________________________________(1/1)
x \/ x0 <-> count_truths ldp >= 1
- [Coq-Club] Unprovable obligation generated by Program Definition, Robin Green
- Re: [Coq-Club] Unprovable obligation generated by Program Definition, Matthieu Sozeau
