- From: "Elie Soubiran" <soubiran AT lix.polytechnique.fr>
- To: "Julien Tesson" <julien.tesson AT univ-orleans.fr>
- Cc: "Mailing list Coq" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Module derivation ?
- Date: Mon, 15 Sep 2008 12:46:48 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:cc:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=HZj/uEEY0N1DgWRdb/XNLW7cl2Iq3DKt0diD+SHzOW3nqHaxnVU0waoqsHqLQAqJVi Y4TP0mZrEJ0qGKlvUCsfKyncjxjVL6fXXYEdw2Fkg4tFs7lsORZ0teePKeZ3zswVKhRC 5n211pDy3YyA+gununEi3a8uOaIJYbac9zwzM=
Hello Julien,
In Coq V8.2 beta (http://coq.inria.fr/V8.2beta) you can use the
Include keyword to factorize your developement:
Module Type B.
Parameter C : Set.
Parameter rel : C->C->Prop.
Axiom rel_trans :
forall (c1 c2 c3 : C) , rel c1 c2-> rel c2 c3 -> rel c1 c3.
End B.
Module Type B1.
Include Type B.
(* copy the fields of the module type B in the current module type*)
Axiom Specific_B1_Axiom :
forall (c : C) ...
End B1.
Module Type B2.
Include Type B.
Axiom Specific_B2_Axiom :
forall (c : C) ...
End B1.
Elie
2008/9/15 Julien Tesson
<julien.tesson AT univ-orleans.fr>:
> Hi,
> I have the following modelling problem :
> I have two module types which contain some similar fields and I'd like to
> factorize them in one module.
> example :
> for two module B1 and B2
> Module Type B1.
> Parameter C : Set.
> Axiom rel_trans :
> forall (c : C) ...
> End B1.
> Module Type B2.
> Parameter C : Set.
> Axiom rel_trans :
> forall (c : C) ...
> End B2.
> I'd like to do something like
> Module Type B.
> Parameter C : Set.
> Axiom rel_trans :
> End B.
> and deriving from B the module types B1 and B2 that embed their specific
> axioms.
> The coq'art suggest to write
> Module Type B1.
> Declare Module root : B.
> End B1.
> but it's not satisfying to me because it force to use B1.root.C to access C
> instead of B1.C .
> Is there a way to derive a module from an other one more transparently so
> that I can access C through B1.C ?
> Best Regards,
> Julien.
- [Coq-Club] Module derivation ?, Julien Tesson
- Re: [Coq-Club] Module derivation ?, Stéphane Lescuyer
- Re: [Coq-Club] Module derivation ?, Elie Soubiran
Julien Tesson
- Re: [Coq-Club] Module derivation ?, Luke Palmer
Julien Tesson
