- To: Andreas K�gi <acepublic AT fastmail.fm>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: Newbie Questions on Module Type usage
- Date: Tue, 16 Sep 2008 09:50:17 +0200
Andreas Kägi wrote:
Thanks four your help, Yves.The module / interface mechanisms make that there are three "moments" of usage:
I was probably too much thinking in a Java analogy of interfaces and classes.
I thought I only had to produce a value A of type Set and a module M1sub
satisfying the signature of MT1. But apparently, I cannot use the
definitions/module types defined in a module type within the corresp. module
implementation?
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- when you are defining a module type,
- when you are defining a module (satisfying --or instantiating-- a module type),
- when you are using a module.
When you are defining a module (2nd moment of usage), you cannot assume that all
the fields of the module type are already provided, on the contrary you have to show
that you know how to construct them.
When you are defining a module type, you make promises, when you define a module
satisfying a module type, you claim that you will fulfill all the promises (so, you make
promises again). The claim is checked when you type "End ...".
Normally, when you use a module, you can only use what was promised for in the
module type. This discipline makes it possible to replace the module with another
one providing a different implementation for the same functionality.
I am not sure about your Java analogy, but if you can use what you should be defining
before it is completely defined, you enter a domain of recursive definitions where it
becomes difficult to know when things are really defined. We are accustomed to this
in conventional programming language, where recursive values sometimes are
unusable (because a recursive function loops, for instance), but theorem provers are usually
more careful about having a definite value for everything that is encountered (and
for instance, theorem provers provide a restricted form of recursion, with guaranteed
termination).
Yves
- [Coq-Club] Newbie Questions on Module Type usage, Andreas Kägi
- Re: [Coq-Club] Newbie Questions on Module Type usage, Yves Bertot
- [Coq-Club] Re: Newbie Questions on Module Type usage,
Andreas Kägi
- Re: [Coq-Club] Re: Newbie Questions on Module Type usage, Yves Bertot
