- To: "Julien Tesson" <tesson.julien AT free.fr>
- Cc: "Mailing list Coq" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] name of term in tactics
- Date: Mon, 29 Sep 2008 14:52:39 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:cc:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=wUFPepmY1IMDwVfnQtr8lfk0R5yt7coLSeMDUq2yOGeRzvZSMrlHE1IXuiQAdIu7s9 b1AalR+HVXArmJ0qVP08499DYZptB0fznPmQNcDxBab7OGAniDunvdYHyOLeeDf/e2kh GAu4Jf34fJ8lIdDiWIsyL2pik0eKgHanphe9s=
Hi, you can just write
| exists x, _ => elim e; clear e; intros x e
in the 'exists' branch and this will use the x from the matched term.
It's the same as writing
| exists x, _ => destruct e as [x e]
The problem in both cases is that the tactic will fail if there is
already an object named x in the context.
Unfortunately it seems impossible to use the metavariable x as an
argument to fresh, so I cant think of a way to make it work in
general.
Maybe you could resort to passing a correct name as an argument to the tactic
Stéphane L.
2008/9/27 Julien Tesson
<tesson.julien AT free.fr>:
> Hi,
> Is there a convenient way to re-use the name of a term in tactics definition
> here is an example of what I'd like to do :
> Ltac elim_ex e:=
> repeat (
> match (type of e) with
> | exists x,_ =>
> elim e;clear e; let H:=fresh "x" in intros H e
> | _ => fail
> end
> I'd like to replace "x" with something that give me the name of the subterm
> x in the matched term, is it possible ?
> Thanks in advance,
> Julien.
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
- [Coq-Club] name of term in tactics, Julien Tesson
- Re: [Coq-Club] name of term in tactics, Stéphane Lescuyer
