- From: "Elie Soubiran" <soubiran AT lix.polytechnique.fr>
- To: "Edsko de Vries" <devriese AT cs.tcd.ie>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] coqide on Darwin
- Date: Tue, 30 Sep 2008 16:46:08 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:cc:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=jM3C1d/gAApu1zwARQ+uEZeUNydhj6B3ujVdh8hCaomyYaF/IDt4ChscFYRjqsKcXe 36ToYILYOXJ8DA0zibUNUNVy0afRyI2+CCW4IyrgF+ItRfhhT+0QJSobvduDOk/78bG2 TvQq8vjkpOuAZum6QuGhc91clfQx1Ora7n6vE=
Hello,
You can either compile Coq/Coqide manually, in that case you just need
to install lablgtk2 with fink, or you can take a look to my homepage to check
if more recent releases (8.1pl3 and V8.2beta) work better for you.
http://www.lix.polytechnique.fr/Labo/Elie.Soubiran/fink/
Elie
On Tue, Sep 30, 2008 at 4:01 PM, Edsko de Vries
wrote:
> Hi,
> I have just received my new Apple iMac and I'm trying to install coqide.
> I tried macports first, which has coq 8.1pl3, but doesn't appear to
> support coqide. Uninstalled that and installed the slightly older
> (8.1pl2) DMGs from the coq website instead. I now have coqc, but running
> coqide complained about a missing gtk library. Used fink to install
> gtk+2, and tried again. It now complains:
> dyld: Library not loaded: /usr/X11/lib/libfontconfig.1.dylib
> Referenced from: /usr/X11R6/lib/libXft.2.dylib
> Reason: Incompatible library version: libXft.2.dylib requires version
> 5.0.0 or later, but libfontconfig.1.dylib provides version 2.0.0
> Any ideas? I'm unfortunately no Mac expert (but so far I'm less than
> impressed by the Mac package management systems..)
> Edsko
> Bug reports: http://logical.futurs.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] coqide on Darwin, Edsko de Vries
- Re: [Coq-Club] coqide on Darwin, Elie Soubiran
- Re: [Coq-Club] coqide on Darwin, Edsko de Vries
