- To: Cedric.Auger AT lri.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] problems in compiling coqide (openSUSE)
- Date: Fri, 10 Oct 2008 00:31:23 +0200
- Openpgp: id=FCE03DAA
AUGER Cédric wrote:
> I just wanted to compile trunk version of coq, but i failed in compiling it:
> I don't have dlllablgtk2.so in /usr/lib64/ocaml/stublibs/, looking closer
> in the lablgtk2 package from openSUSE 11.0 (x86_64) with Linux
> 2.6.25.16-0.1-default x86_64
> i found that this file wasn't provided, any body knows if the package is
> incomplete or that such a file won't be required anymore in the future?
It's incomplete. I would even say the contrary: it will be required in
the best (for some definition of best) situation.
> Is there a way to install the last version of coqide in an other way?
Try this:
1. make distclean
2. ./configure -coqrunbyteflags -custom <whatever-options-you-want>
3. make
If it works, this would be a workaround to missing dlllablgtk2.so. But
try to get the lablgtk2 package fixed in openSUSE.
Cheers,
Stéphane Glondu
- [Coq-Club] problems in compiling coqide (openSUSE), AUGER Cédric
- Re: [Coq-Club] problems in compiling coqide (openSUSE), Stéphane Glondu
