coq-club - Re: [Coq-Club] Copy/paste from CoqIde right-side windows
chronological Thread
  • To: Eugene Kirpichov <ekirpichov AT gmail.com>
  • Cc: Adam Chlipala <adamc AT hcoop.net>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Copy/paste from CoqIde right-side windows
  • Date: Wed, 15 Oct 2008 16:41:30 +0100
Eugene Kirpichov wrote:
Probably I am a bit atypical since I prefer vim :)
Actually, I had already installed emacs and started to install Proof
General when Eric Jaeger told me that it I can drag and drop that text
into the editor window, where it becomes copyable. So, the problem is
solved, but thanks anyway :)
Also, as I just discovered, you can middle-click to paste text from the other panes. This goes for text that is selected within those panes as well as that which was copied (using the Copy command).
The fact that the Paste command does not paste such text is somewhat bizarre. It does work, after all, for text copied from within the file tabs. Why should the other panes copy to a different clipboard?
Ezra
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
