coq-club - Re: [Coq-Club] unload prelude?
chronological Thread
  • To: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] unload prelude?
  • Date: Wed, 29 Oct 2008 15:59:28 +0000
Thank you & Laurent & Georges (in private) for you helpful comments.
I guess I was looking for something like
Reset Initial "-nois"
available as a vernacular command. But this doesn't seem to exist.
I guess I'll get away with redefining the prelude and taking care of the notational expansion.
Cheers,
Thorsten
On 29 Oct 2008, at 15:48, Pierre Letouzey wrote:
On Wed, Oct 29, 2008 at 11:35:05AM +0000, Thorsten Altenkirch wrote:
Section nat.
Inductive nat : Set :=
 | O : nat
 | S : nat -> nat.
Lemma O_S : forall n:nat, 0 <> S n.
As Laurent already mentionned, beware of the "0" notation ...
What would be the best way of achieving this. I guess I can run coq
without the prelude, but this would require special instructions how
to start Coq. Is there a way to "unload" the prelude (or parts of it)
as part of a coq script?
I'm not aware of any "unload" feature, but you can indeed start coq
without its prelude, see the option -nois (meaning: no input state)
that both coqtop and coqide accept.
Of course, this way you start with precisely *nothing* in your
environment. You'll probably want at least some notion of equality
(as in the "<>" of your example) : you can either provide your own,
or load some specific parts of the prelude, for example via a
Require Import Logic.
Note that some advanced tactics may also be unusable since they may
need some objects of the prelude.
Best,
Pierre Letouzey
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
