- From: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
- To: Andrew McCreight <continuation AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: Help with a seemingly obvious proof.
- Date: Thu, 30 Oct 2008 22:34:50 +0100
On Thu, Oct 30, 2008 at 01:19:13PM -0700, Andrew McCreight wrote:
> If there's a better way to prove these sorts of things, I'd love to know
> about it.
> -Andrew
Hi Satrajit, Hi Andrew,
Indeed, proving things about Zdiv can be quite tedious. In particular,
lots of properties are lacking in the Zdiv.v file of Coq 8.1 and
earlier. Some months ago, I've tried to improve this situation, by
collecting various tids and bits about Zdiv and adding mine. As a
result, the Zdiv.v coming along with the next version 8.2 should be
more decent. Beta versions of this 8.2 are already available, I
encourage you to have a test and check whether this new Zdiv.v fits
your needs, see http://coq.inria.fr/V8.2beta/. The content of Zdiv.v
can be accessed directly at:
https://gforge.inria.fr/plugins/scmsvn/viewcvs.php/branches/v8.2/theories/ZArith/Zdiv.v?root=coq&view=markup
For instance, your example can now be proved this way:
Lemma test : forall z,
z > 0 -> z <> 1 -> 4*(z-1)/4-1 >= 0.
Proof.
intros.
apply Zle_ge. (* we switch from >= to <= (more results about <=) *)
apply Zle_minus_le_0. (* we move the -1 to the left hand-side *)
apply Zdiv_le_lower_bound; auto with zarith.
Qed.
Best,
Pierre Letouzey
PS: Since the initial exemple mentionned things like int32 that sounds
quite hardware-related, you might be interested by two other additions
to this forthcoming 8.2 :
- I've added an alternate division named ZOdiv (see ZOdiv_defs.v and
ZOdiv.v at the same place as Zdiv.v). The idea is that (Zdiv a b) when
(b<0) does _not_ follow the convention of most languages (Ocaml,C,...)
and processors. Unfortunately, we cannot say that there is a "good"
or "bad" behavior, so instead of "fixing" Zdiv, we propose now two
variants.
- Coq 8.2 also provides Int31 integers in the spirit of Ocaml (see
theories/Numbers/Cyclic/Int31/Int31.v). These bounded numbers are used
in particular to provide efficient arbitrary-size integers: usual
operations upon Int31 will be computed primitively by the hardware.
You might be interested to know that this Int31.v has been carefully
crafted as to be independent of 31, you can obtain an Int32.v by a
simple sed -e "s/31/32/g", you will simply loose the "hardware
acceleration".
- [Coq-Club] Re: Help with a seemingly obvious proof., Satrajit Roy
- Re: [Coq-Club] Re: Help with a seemingly obvious proof.,
Andrew McCreight
- Re: [Coq-Club] Re: Help with a seemingly obvious proof., Pierre Letouzey
- Re: [Coq-Club] Re: Help with a seemingly obvious proof., Satrajit Roy
Andrew McCreight
