- To: Thery Laurent <thery AT ns.di.univaq.it>
- Cc: rouxcody AT loria.fr, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] well founded induction computation
- Date: Thu, 13 Nov 2008 13:32:43 +0100
Thery Laurent wrote:
Actually, it would not make you loose reduction if the proofs you are rewriting with were transparent enough to be reducible to refl_equal...
What is happening here? Otherwise I completely agree that programming by proof as I have done is quite disadvisable.
The problem is your two subst in your wf_fix.
Unfortunately, rewriting in dependent types makes you lose
reduction.
Laurent Théry
Yves
- [Coq-Club] well founded induction computation, rouxcody
- Re: [Coq-Club] well founded induction computation,
Thery Laurent
- Re: [Coq-Club] well founded induction computation, Yves Bertot
Thery Laurent
