- To: Brian Aydemir <baydemir AT cis.upenn.edu>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Working with typeclasses in 8.2beta
- Date: Sun, 23 Nov 2008 21:53:56 +0100
Le 23 nov. 08 à 20:18, Brian Aydemir a écrit :
Hi,
Hi,
I have a question about working with type classes in 8.2beta. In case
it matters, I'm currently using the subversion branch (r11609). I'll
being with some commented code to illustrate my question.
<snip/>
(* Let's try working with the class now. *)
Lemma test : forall t1 t2,
twiddle 2 (bar_two t1 t2) = bar_two t1 t2.
Proof.
intros.
simpl.
(* The goal is:
bar_two (twiddle_bar 2 t1) (twiddle_bar 2 t2) = bar_two t1 t2
While not surprising, one might hope for the following instead,
especially since [rewrite twiddle_ax] and [f_equal; apply twiddle_ax]
fail on the above.
bar_two (twiddle 2 t1) (twiddle 2 t2) = bar_two t1 t2
change twiddle_bar with (@twiddle bar _).
do 2 rewrite twiddle_ax.
reflexivity.
Qed.
In the above code, I saw twiddle_bar where I wanted to see twiddle. I
couldn't apply facts about twiddle because "twiddle_bar" and "twiddle"
didn't match in any way (so the error messages tell me).
In general, I imagine that when working with type classes, I want to see
things in terms of the abstractions those classes provide, because I'm
likely to have all my theorems and other definitions stated in terms of
those abstractions, and I'm likely to be thinking in terms of those
abstractions. I don't want to see the names of the definitions for
specific instances if I can avoid it.
There's a choice to make because even if you don't want to see [twiddle_bar]
here, you still want to get it's reduction behavior. Having one without the other
seems impossible to me. However having a [fold] command that works up
to typeclasses could help recover the abstraction more easily.
In the above example, I used the [change] tactic, in some sense, to
restore the abstraction provided by the type class. Is there any advice
on how to do this in general, or to avoid the problem altogether?
Alternatively, am I thinking about type classes in the wrong way? I
would appreciate hearing people's thoughts on this.
I've not enough experience for definite statements, all I can say is that I
never had this issue before. I guess that's mainly because I usually didn't
use the abstract methods to reason on effective code but mostly used them
after the fact and to reason on the abstract structures. Currently I have no
better suggestion than a folding tactic. Even if you add sufficient information
to the [twiddle_ax] lemma to infer the instance, [rewrite] won't unify
[twiddle 2 t1] and [twiddle_bar 2 t1] due to restrictions on the delta- reductions
allowed.
I guess users of Canonical Structures may have had a similar problem.
Application of the [rewrite] lemma on the simplified goal would require
infering "back" the [Twiddle_bar] record during unification. The ssreflect
[rewrite] might be able to do that (simply declaring [Twiddle_bar] as
canonical in Coq doesn't work of course).
Cheers,
-- Matthieu
- [Coq-Club] Working with typeclasses in 8.2beta, Brian Aydemir
- Re: [Coq-Club] Working with typeclasses in 8.2beta, Matthieu Sozeau
- RE: [Coq-Club] Working with typeclasses in 8.2beta, Georges Gonthier
