coq-club - [Coq-Club] available context in refine 'holes'
chronological Thread
  • From: "Kouskoulas, Yanni A." <Yanni.Kouskoulas AT jhuapl.edu>
  • To: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] available context in refine 'holes'
  • Date: Sun, 11 Jan 2009 11:45:00 -0500
  • Accept-language: en-US
  • Acceptlanguage: en-US
Greetings,
My apologies if this question has already been answered, but I looked through
the archives and did not see it before.
I find that when using refine, the context that I have access to lacks
assumptions that I think should be available. Consider the following somewhat
contrived example:
Section foo.
Variable lprop : list nat -> Prop.
Theorem bar (i : list nat) : nat -> lprop i -> nat.
refine((fix f (i : list nat) (p : nat) (prf : lprop i) {struct p} : nat  :=
  match p with
    | S (S (S (S q))) =>
      match i with
        | nil => 1
        | h :: tl => (f tl q _)
      end
    | _ => 0
  end)).
The refine tactic puts me in a proof environment that asks me to prove "lprop
tl", which is correct, but it will not include information in the context
about how tl relates to lst, i.e., lst = h :: tl. This is information that
seems derivable from the match construct.
To address this problem when I encounter it, I end up making my hole bigger,
  match p with
    | S (S (S (S q))) => _
    | _ => 0
  end)).
and then using tactics to reconstruct the match that I took out. Is there a
better way to use refine so that it gives me more detailed context? Widening
holes like this seems like extra work to me.
-Yanni
