coq-club - [Coq-Club] [ANN] The Ynot library for imperative programming in Coq
chronological Thread
  • To: Coq Mailing List <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] [ANN] The Ynot library for imperative programming in Coq
  • Date: Sun, 18 Jan 2009 20:05:58 -0500
We would like to announce the first official release of the Ynot library, available at:
   http://ynot.cs.harvard.edu/
Ynot is a library for Coq which turns it into a full-fledged environment for writing and verifying imperative programs. In the tradition of the Haskell IO monad, Ynot axiomatizes a parameterized monad of imperative computations, where the type of a computation tells you not only what type of data it returns, but also what Hoare-logic-style precondition and postcondition it satisfies. On top of the simple axiomatic base, the library defines a separation logic. Specialized automation tactics are able to discharge automatically most proof goals about separation-style formulas that describe heaps, meaning that building a certified Ynot program is often not much harder than writing that program in Haskell.
Ynot makes it easy to enhance its automation with support for new predicates describing new data structures, and, since all such enhancements must be proved from first principles, extensibility does not require users to trust more code. All of Coq's traditional theorem-proving tools are available by default as well. Thus, Ynot enables effective proof-based software engineering, from simple memory safety of low-level imperative programs to deep correctness theorems about programs like compilers that may use imperative data structures for efficiency.
P.S.: We've been developing under Coq 8.1 and recently learned that our build process runs into an infinite loop in Coq 8.2. We'd be really grateful for any patch that someone might come up with to get things working with 8.2.
