- From: Chantal KELLER <chantal.keller AT wanadoo.fr>
- To: crateo <crateo AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] applying PROP's
- Date: Mon, 19 Jan 2009 17:24:27 +0100
Hi,
You can change yout goal into
1 subgoal
x : nat
y : nat
H : 2 * y = x \/ 1 + 2 * y = x
______________________________________(1/1)
2 * S y = S (S x)
by apply the tactic "unfold div2P in H."
But what you say next is not true : "2*y = x" is not a consequence of
H!! You would have to prove your current goal under the hypothesis "2*y
= x" then under the hypothesis "1+2*y = x"... but this is obviously false !
You shoud not use the tactic "constructor". You first need to destruct
H, before choosing which branch of your goal you are able to prove.
Here is a complete proof:
intros x y h.
unfold div2P in *. (* unfolds the def of div2P everywhere *)
destruct h. (* destructs the or *)
left. rewrite <- H. ring. (* in the first case, you can prouve the
property on the lhs *)
right. rewrite <- H. ring. (* in the second case, you can prouve the
property on the rhs *)
Chantal KELLER.
crateo a écrit :
> Hi, i'm a newbie in all this thing, and i'm struck in this problem. Please,
> give me one answer if you can : P. Here we go:
> I have this in coq:
> Fixpoint div2 (n : nat) : nat :=
> match n with
> |0=> 0
> |S 0=>0
> | S (S p) => S (div2 p)
> end.
> Definition div2P (x y : nat) : Prop := 2 * y = x \/ 1 + 2 * y = x.
> Require Export ArithRing.
> Lemma th : forall x y : nat, div2P x y -> div2P (S (S x )) (S y).
> intros.
> constructor.
> and the result in the console is:
> 1 subgoal
> x : nat
> y : nat
> H : div2P x y
> 2 * S y = S (S x)
> The thing is that we know that "div2P x y" is true, by the definition we
> made before. I would want to change it for something like:
> x:nat
> y:nat
> H0:2*y=x \/ 1+2*y=x
> H:2*y=x
> 2*Sy = S(Sx)
> That should not be very difficult, because H0 and H are logical deduction of
> the fact that div2P x y is true.
> How, for the shake of the glory chicken, can i do that?
> Thanks in advance.
Chantal KELLER
- [Coq-Club] applying PROP's, crateo
- Re: [Coq-Club] applying PROP's, Edsko de Vries
- Re: [Coq-Club] applying PROP's, Luke Palmer
- Re: [Coq-Club] applying PROP's, Chantal KELLER
- Re: [Coq-Club] applying PROP's, Jean-Francois Monin
