coq-club - Re: [Coq-Club] FMap on Int
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Cc: ashish AT darbari.org
  • Subject: Re: [Coq-Club] FMap on Int
  • Date: Tue, 20 Jan 2009 17:02:28 +0100
You're missing the fact that the FMapAVL.Make functor expects a module compatible with the OrderedType module type,
and this type requires the definition of the "lt" field, representing the order relation.
I don't know nothing about extraction, but if you absolutely want to use Ints, you can define a Int_as_OT functor as follow:
Module Int_as_OT(I:Int) <: OrderedType.
 Import I.
 Definition t := int.
 Definition eq x y := eq (i2z x) (i2z y).
 Definition lt x y := (Zlt (I.i2z x) (I.i2z y)).
 Lemma eq_refl : forall x : t, eq x x.
   intros;reflexivity.
 Qed.
 Lemma eq_sym : forall x y : t, eq x y -> eq y x.
   symmetry.
   assumption.
 Qed.
 Lemma eq_trans : forall x y z : t, eq x y -> eq y z -> eq x z.
   intros.
   unfold eq in *.
   rewrite H.
   assumption.
 Qed.
 Lemma lt_trans : forall x y z : t, lt x y -> lt y z -> lt x z.
   intros.
   unfold lt in *.
   apply Z_as_OT.lt_trans with (I.i2z y);auto.
 Qed.
Lemma lt_not_eq : forall x y : t, lt x y -> ~ eq x y.
   intros.
   unfold lt in *.
   apply @Z_as_OT.lt_not_eq.
   assumption.
 Qed.
 Lemma compare : forall x y : t, Compare lt eq x y.
   intros;destruct Z_as_OT.compare with (i2z x) (i2z y).
   apply LT;auto.
   apply EQ;auto.
   apply GT;auto.
 Qed.
 Lemma eq_dec: forall x y:t, {eq x y}+{~ eq x y}.
   intros x y.
   unfold eq.
   do 2 decide equality.
 Qed.
End Int_as_OT.
Module Zint := Z_as_Int.
Module OrderedInt := Int_as_OT( Zint).
Module IMap1 := FMapAVL.Make(OrderedInt).
Ashish Darbari wrote:
I'm having problems able to use the FMapAVL.
It works out quite fine if I want the keys to have the type z (IMap), but since I want to use
this map in ocaml extracted code where keys
will be ocaml integers, I want to define the
equivalent module (IMap1) in Coq on Ints, but
when I do it as shown below, I get an error,
No such label lt.
What am I missing?
Thanks
Ashish
Require Import ZArith.
Require Import OrderedType.
Require Import OrderedTypeEx.
Require Import FMapAVL.
Require Import Int.
Module IMap := FMapAVL.Make(Z_as_OT).
Module IMap1 := FMapAVL.Make(Z_as_Int).
