- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] problem refine tactic with fix construction ---> bug in coq?
- Date: Tue, 20 Jan 2009 18:30:34 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type :content-transfer-encoding:content-disposition; b=OoqbTWRD/nFYir+QExngIu6LKvAynxn2EATItYfTmxrW7Pjl6IrqfyVY9rffzOL5/T Rgf8svrHM3EH2+Al76ObMXJNh/SACgO8U0KcVUlUR1VNMLuO4BsZzKx2wL0N4m99xGcY tMZi7a8yQqUpXKzfgsXnKwFI5/KJ8xpzbCXe8=
Dear all,
I use coqide from coq 8.1pl1. In coqide I start the following proof
Inductive test1: Set
:= a: test1 | S1: test2 -> test1
with test2: Set
:= b: test2 | S2: test1 -> test2.
Definition test: test1 -> nat.
refine
(fix g (t1: test1): nat := _
with f (t2: test2): nat := _
for g).
The result of this is
2 subgoals
g : test1 -> nat
f : test2 -> nat
t1 : test1
______________________________________(1/2)
nat
______________________________________(2/2)
nat
This is as I expected, but if I change the order of the two branches
of the fix construction as in
refine
(fix f (t2: test2): nat := _
with g (t1: test1): nat := _
for g).
I get
2 subgoals
f : test1 -> nat
g : test1 -> nat
t2 : test1
nat
nat
Note that the type of f is not the same as given in the refine tactic.
Is this a bug in coq?
All the best,
Chris
- [Coq-Club] problem refine tactic with fix construction ---> bug in coq?, Chris Dams
