- To: Coq Club <coq-club AT pauillac.inria.fr>
- Cc: Eric Jaeger <eric.jaeger AT sgdn.gouv.fr>
- Subject: Re: [Coq-Club] Transformations under a binder
- Date: Wed, 21 Jan 2009 14:18:03 +0100
Le 20 janv. 09 à 08:22, JAEGER, Eric (SGDN) a écrit :
Hi,
I have quickly investigated possible transformations (reduction, unfolding, rewriting) under a binder. When the binder do not bind a free variable in the term (e.g. f(0) in forall (n:nat), ...f(0)...) it is possible to unfold, reduce and rewrite this term. When the binder capture a free variable (e.g. f(n) in forall (n:nat), ...f(n)...) it is possible to unfold but not to reduce (except if after unfolding the bound variable disappear, e.g. by defining f(n m:nat)=f' n) or to rewrite - the situation appears similar either using a forall or a match (forall (n:nat) bind n, while match n as 0 =>... | S n' => ... bind n').
So here is my question: Provided I have a function leb:bool->bool s.t. leb_0:forall (n:nat), leb 0 n=true holds, is there a tactic in Coq to rewrite a term of the form (leb 0 n) under a binder capturing n, without having to first eliminate this binder? In other words, is there a way to prove the theorem test below WITHOUT using intros / destruct?
Variable leb:nat->nat->bool.
Axiom leb_0:forall (n:nat), leb 0 n=true.
Theorem test:forall (n:nat), match n with
| 0 => leb 0 0=leb 0 (S n)
| S n' => leb 0 n'=leb 0 n
end.
Proof.
intros n.
destruct n as [| n].
rewrite leb_0; rewrite leb_0; apply refl_equal.
Qed.
Hi,
This is possible using the latest (8.2) setoid-rewriting tactic, but
not in the case of match constructs which are a bit hard to handle
generically. If instead of the match you used the following:
Require Import Setoid.
Definition nat_case (P : Type) (z : P) (s : nat -> P) (n : nat) : P :=
match n with 0 => z | S n' => s n' end.
(** We can actually fold any (non-dependent) case analysis into a [nat_case] *)
Ltac fold_nat_case :=
match goal with
[ |- context [ match ?x with 0 => ?z | S n' => @?s n' end ] ] => fold (nat_case _ z s x)
end.
(** Defining a morphism that allows to rewrite inside the "S" case if we
maintain logical equivalence. Of course this requires a case analysis. *)
Instance nat_case_morp :
Morphism (iff ==> (pointwise_relation nat iff) ==> @eq nat ==> iff) (nat_case Prop).
Proof.
reduce. subst x1. destruct y1 ; firstorder.
Qed.
(** Now we just need to rewrite with the lemma using the [setoid_rewrite] variant
([rewrite] doesn't try to go under lambdas for compatibility). Actually, the semantics
of [setoid_rewrite] is a bit different: it rewrites _all_ the subterms that unify with
the lemma, in their local contexts. Hence it rewrites all [leb 0 _] subterms in one go.
One could use [at] to control which occurences should be rewritten. *)
Theorem test':forall (n:nat), match n with
end.
Proof. intros. fold_nat_case.
setoid_rewrite leb_0.
induction n ; reflexivity.
Qed.
You can rewrite under forall/exists/you-name-it binders as well using the same principle.
Hope this helps,
-- Matthieu
- [Coq-Club] Transformations under a binder, JAEGER, Eric (SGDN)
- Re: [Coq-Club] Transformations under a binder, Taral
- Re: [Coq-Club] Transformations under a binder, Matthieu Sozeau
- [Coq-Club] Coq connecting to other provers,
Benedikt . AHRENS
- Re: [Coq-Club] Coq connecting to other provers,
Yves Bertot
- Re: [Coq-Club] Coq connecting to other provers, Thery Laurent
Yves Bertot
Benedikt . AHRENS
