- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Packaging extract without writing Ocaml code
- Date: Fri, 23 Jan 2009 16:38:51 +0100
Hello,
I devised a small module containing axioms and the corresponding ocaml code to help
produce programs directly from Coq developments. The idea is that users can develop
their own function from Z to Z, and the module provides the packaging to build a program
that makes it easy to run this function on a sequence of numbers and produce the corresponding
sequence of outputs. This module is available at the following address:
http://logical.saclay.inria.fr/cocorico/ZInterfacePackage
Here are the first lines from the package description:
We propose a Coq module, named *Z_interface* that provides two constants (to begin with).
* input_stream_Z : Stream Z,
accessing this stream will read the extracted program's input, assuming this input is solely composed of decimal representations of numbers (one per line),
* output_stream_Z : (stream Z) -> unit,
passing a stream to this function will provoke the output of decimal representations of all members in the stream to be printed by the program.
To use this, you simply need to define a constant of type unit whose value is computed by output_stream_Z in you Coq code, then you extract the code, and compile it.
Here is an example of use:
Require Import ZArith Streams Z_interface.
Open Scope Z_scope.
Definition final := output_stream_Z(Streams.map (fun x => x + 2) input_stream_Z).
Extraction "adds_two.ml" Zdiv_eucl Z_to_n_int final.
We need to include the extraction of Zdiv_eucl and Z_to_n_int
because they are used in the ocaml values for the axioms.
To use the extracted code, you simply need to compile the two generated ml files:
ocamlc adds_two.ml
ocamlc -o adds_two adds_two.mli
./adds_two < ex.txt > ex1.txt
Assuming the file ex.txt contains the strings "1" "2" ..."5", each on a line, the result file ex1.txt will contain the strings "3" "4" ... "7".
- [Coq-Club] Packaging extract without writing Ocaml code, Yves Bertot
