- From: Matt Ridsdale <matt.ridsdale AT cl.cam.ac.uk>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Check lemma_name gives error immediately after lemma is proved
- Date: Sun, 8 Feb 2009 08:41:07 -0800 (PST)
Hi
I'm getting to know Coq and have proved 0 + x = x + 0 as a simple example.
I want to be able to re-use this result in proving further theorems.
Can anyone tell me why the result is accessible in the current environment
if
I prove it for Coq's native type nat, but not if I define nat myself using
the "Inductive" keyword?
Below is the Coq code and error message.
(* This works fine *)
Lemma z_plus_commutes : forall y:nat, plus 0 y = plus y 0.
intro y; elim y; auto; intro m; intro; simpl; rewrite <- H; simpl; auto.
Qed.
Check z_plus_commutes.
Coq < z_plus_commutes
: forall y : nat, 0 + y = y + 0
(* This gives an error *)
Inductive mynat : Set :=
| Q : mynat
| T : mynat -> mynat.
Definition myprim_rec := mynat_rec (fun i:mynat => mynat).
Definition myplus (n m:mynat) := myprim_rec m (fun p rec:mynat => T rec) n.
Lemma z_plus_commmutes : forall y : mynat, myplus Q y = myplus y Q.
Qed.
Coq < Toplevel input, characters 7-22
Error: The reference z_plus_commutes was not found in the current
environment
Apologies if this is something obvious, but I've looked through the forums
and a couple of tutorials
and can't see anything that relates to it.
cheers,
Matt
View this message in context:
http://www.nabble.com/Check-lemma_name-gives-error-immediately-after-lemma-is-proved-tp21900669p21900669.html
Sent from the Coq mailing list archive at Nabble.com.
- [Coq-Club] Check lemma_name gives error immediately after lemma is proved, Matt Ridsdale
