coq-club - Re: [Coq-Club] problems while trying to recompile compcert with the trunk 11850
chronological Thread
  • To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
  • Cc: Cedric Auger <Cedric.Auger AT lri.fr>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] problems while trying to recompile compcert with the trunk 11850
  • Date: Mon, 09 Feb 2009 15:55:19 +0100
Stéphane Lescuyer a écrit :
Hi Cedric,
OrderedType.t and FSetInterface.S.t used to be of type Set. This
prevented (for no reason) developers to build finite sets whose
elements were in Type and not in Set. For that reason they have both
been changed to Type which is a very wishable update indeed, but leads
to some incompatibilities with earlier developments. It should be
fairly straightforward to fix your files, by changing the appropriate
occurrences of Set to Type.
I am not so sure since Set is extracted to caml, but not Type (if I well understood).
If I replace Set with Type it may not extract it.
Cheers,
Stéphane
On Mon, Feb 9, 2009 at 1:32 PM, Cedric Auger
 wrote:
Hello, I tried to recompile compcert using the trunk version 11850, and
found:
COQC lib/Lattice.v
File "/users/demons/cauger/Documents/compcert-1.3/lib/Lattice.v",
line 325, characters 0-10:
Error: Signature components for label t do not match.
make: *** [lib/Lattice.vo] Erreur 1
I tried to understand what happened:
it seems that in contrary to
http://coq.inria.fr/library/Coq.FSets.FSetInterface.html ;,
S.t is no longer of type Set but of type Type.
I think, that there has been a non wishable correction in some update; am I
wrong?
Is it an old bug that has been corrected since?
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
        http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Cédric AUGER
