- From: Ashish Darbari <ashish_darbariuk AT yahoo.co.uk>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Problem with a Proof
- Date: Tue, 10 Feb 2009 11:44:24 +0000 (GMT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.co.uk; h=Message-ID:Received:X-Mailer:Date:From:Reply-To:Subject:To:MIME-Version:Content-Type; b=K16QNGj4WxjglqxfF03J0c1mPnd8lPTVJSV3/3AK6uHp04IZH1hyAW/Ms2KIE3UvIkZbxJUn/yAj69LkcXv/lIhES1h/ZrzkeHBOXL4+mFaLUNrtzC9WtPrwpZj9FlM5ig4ZlcsBzPJiurxPyt0s6wOCFd38bI56a4IMUa7nwv4=;
I'm trying to do a proof about the following function in which I'm finding myself stuck.
Definition foo (l1 l2:list Z)(acc:list Z):(list Z).
refine (fix foo_l1 (l1 :list Z):list Z -> list Z -> (list Z) := _).
refine (fix foo_l2 (l2: list Z):list Z -> (list Z) :=
_).
refine (
fun acc =>
match l1,l2 with
| nil,l2 => app acc l2
| l1,nil => app acc l1
| x::xs, y::ys =>
if Z_eq_dec x y then
foo_l1 xs ys (x::acc)
else if Z_lt_dec (Zabs x)(Zabs y) then
foo_l1 xs (y::ys) (x::acc)
else if (Z_eq_dec (x + y) Z0) then foo_l1 xs ys acc
else foo_l2 ys (y::acc)
end).
Defined.
I have the following two propositions:
Lemma Prop1 : forall x y:Z, (x <> 0) -> (y <> 0) -> (x+y = 0) -> (x <> y).
Lemma Prop2 :
forall x y:Z, (x+y = 0) -> (~(Zabs x < Zabs y)) /\ (~(Zabs y < Zabs x)).
The theorem am trying to prove is the following:
Goal forall c1 c2 l1 l2, (l1 <> 0) -> (l2 <> 0) ->
NoDup c1 -> NoDup c2 -> In l1 c1 -> In l2 c2 ->
~In l1 c2
-> ~In l2 c1 -> (l1+l2=0) -> (~In l1 (foo c1 c2 nil)).
I start with induction on c1 and c2 and easily discharge 3 out of 4 sub-goals, but in the
4th one I find myself stuck when having to unfold foo and not able to reduce the goal
any further.
Proof.
induction c1;induction c2.
intros.
inversion H3.
intros.
inversion H3.
intros.
inversion H4.
intros.
generalize (Prop2 (l1:Z) (l2:Z));intros.
generalize (Prop1 (l1:Z) (l2:Z));intros.
case (Z_eq_dec (l1 + l2) 0);
case (Z_lt_dec (Zabs l1) (Zabs l2));
case (Z_eq_dec l1 l2); intros.
intuition.
intuition.
intuition.
inversion H1;inversion H2.
unfold In in H3;unfold In in H4.
elim H3;elim H4;intros.
rewrite H19;rewrite H18.
The state I have looks like
H13 : NoDup c1
H10 : x = a
H11 : l = c1
x0 : Z
l0 : list Z
H16 : ~ In a0 c2
H17 : NoDup c2
H14 : x0 = a0
H15 : l0 = c2
H18 : a0 = l2
H19 : a = l1
~ In l1 (foo (l1 :: c1) (l2 :: c2) nil)
unfold foo.
at this stage leads me to a state where not sure how
to proceed.
Any help is appreicated,
Thank you
Ashish
- [Coq-Club] Problem with a Proof, Ashish Darbari
- Re: [Coq-Club] Problem with a Proof, Yves Bertot
