- To: Benjamin Pierce <bcpierce AT cis.upenn.edu>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] A more generous coqdoc?
- Date: Sat, 21 Feb 2009 17:03:33 +0100
Le 21 févr. 09 à 15:36, Benjamin Pierce a écrit :
I've been trying to get use coqdoc to make a nice HTML version of my under-construction lecture notes for teaching PL using Coq, but I'm stuck on one serious deficiency: there seems to be no way to get it to keep ordinary comments -- in particular, comments within proofs. I've had a little look inside the code, but I'm afraid I can't understand how it works well enough to see whether this would be easy or hard to change. Can anyone comment on this?
Hi Benjamin,
I can comment :) coqdoc currently skips comments on purpose, in the entry "comment" in file
pretty.mll and it is quite straightforward to make it output the contents instead. Here's a
patch that does it, putting comments in a <span id="comment"> if you add the --parse-comments
option. Feel free to modify and feed back to me.
-- Matthieu
parse_comments.diff
Description: Binary data
- [Coq-Club] A more generous coqdoc?, Benjamin Pierce
- Re: [Coq-Club] A more generous coqdoc?, Matthieu Sozeau
- Re: [Coq-Club] A more generous coqdoc?, Benjamin Pierce
