- From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
- To: Gyesik Lee <gyesik.lee AT aist.go.jp>
- Cc: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Some unexpected warning
- Date: Tue, 3 Mar 2009 23:33:54 +0100
Hi,
> when I try to compile coq codes using first
> coq_makefile *.v > Make
> then it prompts me directly with the following warning:
> Warning: install target will copy files at the first level of the coq
> contributions installation directory; option -R is recommended
> Is this expected change with the newest version of Coq, or was the
> installation something wrong?
> It seems though everything is working well.
This is just a warning. And apparently a not clear enough one. Maybe
also a bit intrusive: it only concerns what will happen if the user
issues a "make install" (the alternative could have been to generate
an "install" target only on demand).
The purpose of "make install" is to copy the current development in
the $COQLIB/user-contrib directory where COQLIB is the installation
directory of coq ($COQLIB/user-contrib is one of the root directory
where Coq is looking by default for compiled files).
In presence of a -R option, say as in "-R . MyLibrary", "make install"
copies the files in $COQLIB/user-contrib/MyLibrary instead of
$COQLIB/user-contrib/, what shifts the risk of accidental file-names
collision to a more visible risk of library-names collision.
In any cases the warning can be ignored. Or it can also be prevented
by adding a -R option as in
coq_makefile -R . MyDevelopment *.v > Makefile
Hope it helps,
Hugo Herbelin
- [Coq-Club] Some unexpected warning, Gyesik Lee
- [Coq-Club] Re: Some unexpected warning, Gyesik Lee
- Re: [Coq-Club] Some unexpected warning, Hugo Herbelin
