- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] interactively constructing witnesses of sig types
- Date: Fri, 06 Mar 2009 04:00:23 +0900 (JST)
Hello.
Could I interactively construct witnesses of sig types?
I have been a happy Coq programmer for a while,
but almost for the first time I use sig types.
Here is a simpler variation on my program:
Variable eq: nat -> nat -> Prop.
Variable eq_refl: forall n, eq n n.
Variable eq_sym: forall n1 n2, eq n1 n2 -> eq n2 n1.
Variable eq_trans: forall n1 n2 n3, eq n1 n2 -> eq n2 n3 -> eq n1 n3.
Record spec: Type := {index:Set; gen: index -> nat}.
Inductive satisfy: spec -> nat -> Prop :=
| satisfy_intro: forall p x n,
eq (gen p x) n -> satisfy p n.
Definition spec_and (p1 p2: spec): spec :=
Build_spec
({x: prod (index p1) (index p2) |
eq (gen p1 (fst x)) (gen p2 (snd x))})
(fun x => match x with exist (n, _) _ => gen p1 n end).
Lemma and_intro: forall p1 p2 n,
satisfy p1 n -> satisfy p2 n -> satisfy (spec_and p1 p2) n.
Proof.
intros p1 p2 n h1 h2.
inversion h1; subst. inversion h2; subst.
At this point the proof context contains:
x: index p1
x0: index p2
and I want to use (x, x0) as a witness by interactively proving
that (x, x0) inhabits the sig type.
I am aware that I can complete the rest of the proof with:
apply (satisfy_intro
(Build_spec
(fun x => match x with exist (n, _) _ => gen p1 n end))
(@exist (prod (index p1) (index p2))
(fun x => eq (gen p1 (fst x)) (gen p2 (snd x)))
(x, x0) (eq_trans _ _ _ H (eq_sym _ _ H0))) n).
simpl. apply H.
However my situation is a little bit more complex than this example, and
I have spent more than 30 min to construct the above "apply" term....
Kind regards,
Keiko
- [Coq-Club] interactively constructing witnesses of sig types, Keiko Nakata
