coq-club - Re: [Coq-Club] Pseudo random numbers in Coq
chronological Thread
  • To: Adam Chlipala <adamc AT hcoop.net>
  • Cc: Marko Malikovi� <marko AT ffri.hr>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Pseudo random numbers in Coq
  • Date: Fri, 06 Mar 2009 15:13:17 +0100
Adam Chlipala wrote:
Marko Malikoviæ wrote:
I'm trying to find some function for generating random (pseudo-random)
numbers in Coq. It seems that it doesn't exists. Am I right?
If it doesn't exists than I need some seed state. But, I don't see some
time (or simmilary) function in Coq.
Every Coq function is pure. It is impossible to write a function of type, e.g., [unit -> nat] that returns different values on different calls. Thus, there can exist no equivalents of C rand() or time(); assuming such a function exists leads to a contradiction.
You can still thread a time or random number seed through a program as an explicit argument/return value, though.
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
I devised one such pseudo-random function a few weeks ago, using two large prime numbers.
CoFixpoint rand (seed n1 n2 : Z) : Stream Z :=
   let seed' := Zmod seed n2 in Cons seed' (rand (seed' * n1) n1 n2).
Now, you would have to choose n1 n2 to be primes, and you would obtain a fairly uniform distribution of numbers between 1 and n2-1. This is not a very good generator, but it was good enough for my purpose of generating large lists of numbers to test the efficiency of various sorting algorithms. Note that, from the Coq
point of view, the whole sequence of numbers is viewed as one single object, and the head of this sequence is always the same: it is your responsibility to read data from the stream further and further as you consumes the generated numbers. This corresponds to threading a time and random number seed as an explicit argument value, as Adam suggests.
Anyway, what is your context of usage? If the random generator needs to interact with extracted code, you can easily adapt the code from
http://logical.saclay.inria.fr/cocorico/ZInterfacePackage
to design a new co-inductive stream similar to input_stream_Z but that would read off a random number generator instead of reading off the standard input.
Yves
