- To: Bruno Barras <bruno.barras AT inria.fr>
- Cc: St�phane Lescuyer <stephane.lescuyer AT inria.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] A simple question
- Date: Fri, 13 Mar 2009 13:52:02 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=FCIBxzyPHGWSM4guS6bMg0dmdFwSwb8u2Q7w6bLtNQt0T9hkQRZcpAgd+fTM6AU5l0 711fXBL+EvHoMXkGdFykHwDlMirUFNCLJhmq0LU3h001wB8WaEvW5+whnCp0m2YLUOLd miA6Pq3RNIFFsyHgaYGZg8Kb0hD2kfK2PnRj8=
Hello again,
Thank you for the responses. I'm writing again because I tried all the
posibilities and it didn't work. Perhaps I'm doing something wrong?
One of the problems that I am having is when I use the Rmult_le_reg_l.
I get two new goals and I don't know how to proof them.
In one of the many ways that I tried, after some simplifications the
only thing that I get was exactly the same inequality that I had at
the beggining. I was wondering if it could be possible to use the
existent lemma Rle_0_1, that says "0 <= 1". Could be possible to
convert the goal 0 <= 87400000020642221000 / 100000000000000000 into
the goal 0 <= 1 by multiplying and dividing both sides of the
inequality? I tried but I couldn't.
The following are two examples of what I did. I didn't complete the
proof even in the case in which I added the two hypothesis "0 <
100000000000000000" and "0 < 87400000020642221000"
So, any suggestion?
Thankyou in advance,
Eric
-----Example 1.
Require Import QArith.
Require Import Reals.
Require Import Fourier.
Open Scope R_scope.
Ltac field_simplify_right :=
match goal with
|- _ <= ?x => field_simplify (x)
end.
Section TEST.
Goal 0 <= 87500000020642221 / 100000000000000000 + -1 / 1000.
field_simplify_right.
At this point the goal is
apply (Rmult_le_reg_l 100000000000000000).
At this point I have two goals.
1) 0 <= 100000000000000000
2) 100000000000000000 * 0 <= 100000000000000000 *
(87400000020642221000 / 100000000000000000)
I don't know how to prove neither (1) nor (2).
-----Example 2 (Adding the Hypothesis h0: 0 < 100000000000000000).
Open Scope R_scope.
match goal with
end.
Theorem aux : forall a b c, c <> 0 -> a * (b / c) = a * b / c.
intros.
field.
assumption.
Qed.
Section TEST.
Hypothesis h0: 0 < 100000000000000000.
assumption.
rewrite Rmult_0_r.
rewrite aux.
(* I don't know how to continue ....
At this point I have 2 goals:
1) 0 <= 100000000000000000 * 87400000020642221000 / 100000000000000000
2) 100000000000000000 <> 0
End TEST.
On Thu, Mar 12, 2009 at 1:47 PM, Bruno Barras
wrote:
> Stéphane Lescuyer a écrit :
>> To prove it "manually", try multiplying both sides by the big
>> (positive) denumerator (Rmult_le_reg_l willbe your friend) and
>> simplify in order to end up with an inequality that automatic tactics
>> can handle.
> Such simplification can be done by field_simplify. Try e.g.
> field_simplifiy (87500000020642221 / 100000000000000000 + -1 / 1000).
> Then use lemma Rmult_le_reg_l, field_simplify again and then fourier should
> apply (last hint: prove x/1=x with field).
> Not as automated as one would expect indeed. Feedback on common situations
> where using field is painful (like this one) is welcome, as it will help us
> improve field.
> In the meantime, crafting a small Ltac script that does it automatically is
> a good exercise and will improve your proof script. (I guess Adam Chlipala
> will agree.)
> Bruno Barras.
- [Coq-Club] A simple question, Eric Biagioli
- Re: [Coq-Club] A simple question,
Stéphane Lescuyer
Stéphane Lescuyer
Bruno Barras
- Re: [Coq-Club] A simple question, Eric Biagioli
- Re: [Coq-Club] A simple question, Stéphane Lescuyer
Bruno Barras
Stéphane Lescuyer
Stéphane Lescuyer
