coq-club - Re: [Coq-Club] Defining data types.
chronological Thread
  • From: "Pierre Cast�ran" <pierre.casteran AT labri.fr>
  • To: dimitrisg7 <dvekris AT hotmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Defining data types.
  • Date: Mon, 30 Mar 2009 20:36:17 +0200
Hi,
May I assume you meant :
Inductive test : Type :=
  test1 : nat -> test
| test2 : nat->nat-> test.
In this case, is the following solution Ok, or did you mean something
else ?
Pierre
Require Import List.
Definition tests := list test.
Inductive Ok2 : tests -> Prop :=
 Ok2_nil : Ok2 nil
|Ok2_cons : forall i j l, Ok2 l -> Ok2 (test2 i j::l).
Inductive Ok : tests -> Prop :=
 Ok_nil : forall l, Ok2 l -> Ok l
|Ok_cons : forall i  l, Ok l -> Ok (test1 i ::l).
Definition Tests := {l : tests | Ok l}.
Quoting dimitrisg7
<dvekris AT hotmail.com>:
Hello!
I have the following inductive definition:
| test1 : nat -> Type
| test2 : nat -> nat -> Type
and I want to define a data type, which is a list of "test" objects. Some
first X items of that list have "test1" as their constructor and the rest
have "test2" as their constructor. Is there a flexible way to define this? I
would rather not break the inductive definition "test" into two pieces.
Thanks everyone!
View this message in context: http://www.nabble.com/Defining-data-types.-tp22785725p22785725.html
Sent from the Coq mailing list archive at Nabble.com.
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Pierre Castéran
