- To: Jeff Terrell <jeff AT kc.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Dependent Functions
- Date: Tue, 31 Mar 2009 10:24:16 -0400
Jeff Terrell wrote:
However, in the case where X references many Y, I'm not sure how to define the function.
CoInductive X : Set :=
Build_X : nat -> list Y -> X
with Y : Set :=
Build_Y : nat -> X -> Y.
This definition type-checks:
CoFixpoint Build_XY (n : nat) (m : nat) : X :=
Build_X n (Build_YX m n :: nil)
with
Build_YX (m : nat) (n : nat) : Y := Build_Y m (Build_XY n m).
...but I'm guessing that this isn't what you're looking for. Can you explain what you are trying to do in your actual example? Co-inductive types have many non-intuitive features, and it's quite possible that you'd be better off reformulating your development at a higher level.
- [Coq-Club] Dependent Functions, Jeff Terrell
- Re: [Coq-Club] Dependent Functions, Adam Chlipala
Jeff Terrell
Jeff Terrell
